Which replacement bulb kit should I buy for an 06 Aygo? Thanks.
and also presuming that your car only has the standard headlight bulbs and not the +50% ,+90% ,+120% brighter bulbs
I think I'm getting to the bottom of this now and have put together a list! The official kit contains one of each bulb except the WY5W (used for side indicators) - these are the amber version of the W5W used for side (parking) lights amongst others. Perhaps this doesn't matter.
Another anomaly for me is which bulb type is used for the FRONT fog lamps - I would guess that they take the P21W. And another thing - why wouldn't the rear lower brake lights take the same as the reversing light, or have I made an error here?
Description Code Size Qty required
Brake P21/5W 380 2
Brake (high mounted) W5W 501 4
Dipped/main beam H4 472 2
Fog (rear) P21W 382 1
Indicator (front) PY21W 581 2
Indicator (rear) P21W 382 2
Indicator (side) WY5W 501A 2
Interior W5W 501 1
Licence plate W5W 501 2
Reversing P21W 382 1
Side (parking) lights W5W 501 2
Tail P21/5W 380 2
Fog (front) ? ? 2
the rear lights use a twin filament bulb number 380 as you know, this is since the one light fitting does two jobs
tail and brake light ,some cars do have separate tail and brake, then the reverse bulb would be used in this instance.
Thanks, that clears that one up, I wondered why the manual said brake/tail light!
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
