12 Pole Blue Electrical Connector Behind The Instruments ?
I'm trying to install a Pekatronic (3-or -5 blinker signal) Comfort Flasher relay in my son's 2008 Aygo http://www.pekatronic.de/product_info.php?info=p92_comfort-flasher-relay.html
I have got instructions with the package, but the 2 last connections on the 12 pole BLUE connector behind the instrument does not tell me all the pin numbers....
I enclose pictures of both rows of pins...One side is numbered, see picture:12 bleue stecker1.jpg
7 - Orange with Grey stripes
8 - White
9 - Yellow
0 - Orange
1 - Violett
2 - Red with Grey stripes
One of the wires on the Pekatronic unit goes to White wire (pin8), in this Blue 12 pole connector...this is for the RHS blinkers...
But ...the LHS Blinker should be connected to pin 11 on this Blue 12 pole connector..Pekatronice says this pin 11 should have a Orange OR Violet wire..but I'm not seeing this colour on this side of the connector OR any pin numbers......Does anyone have a chematic with colors and /or PIN numbers and/or the colour of the wire that goes to the LHS blinkers, to send me ???
OR just tell me which pin is PIN 11 and which colour wire this pin have ??
Regards from Norway
Found out the correct PIN...it was indeed the PIN nr. 1 that was the 11th pin...
so now the Pekatronic unit is working as it should....
post-144254-0-12209000-1413989606_thumb.
post-144254-0-03283500-1413991174_thumb.
