Hello everyone,
I recently bought a new toyota corolla 1.4 2003 T3
I wanted to get an aux cable which fits into the cd changer port but no idea which port is the cd changer on the back or which aux kit will be compatible.
Thanks in advance for your help
Pics are attached
Hi Sohail.
I use a connects2 device and it works great. Had it for over 3 years with no problems. Google it.
Also look at Xcarlink too. Others have tried these with excellent results.
Be aware that around 2004 ish the CD changer socket on the rear of the head unit changed, but the picture of the socket you posted is the same as mine (the early version). It changed to a smaller "more condensed" socket.
Any questions, please reply.
Cheers
Hi Sohail.
Cheers
Thanks for your reply but is it the bigger or smaller socket the CD changer one mate? And I am currently looking at this one but it says it fits a cd changer socket so not sure if it would fit :/
Says compatible with upto 2004 models
http://pages.ebay.com/link/?nav=item.view&id=181136228310&alt=web
thanks
Hi Sohail.
The second picture down shows the CD changer connector (7 pin row and 5 pin row underneath).
The Connects2 USB I have looks to be a later one than the one you listed. Mine has Phono, SD card and USB inputs. CTATYUSB001 is the model.
Take a look at Connects2.co.uk and search under Toyota - Corolla - 2001-2004.
Cheers
Hi Sohail.
Cheers
Yes i had a look at that one mate
does it show which track is playing? On the stereo display
Thanks for your help
Unfortunately our model stereo won't display track name / title, just the track number. The later version stereo does tho, but don't know if it will fit without wiring adapters.
Thanks for all your help mate
I bought this one and fitted it in and does work nicely :)
http://www.ebay.co.uk/itm/350872115890?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
And do i need to worry about timing belt in a corolla 2003 1.4 vvti T3 because after searching online I am being told mixed answers
Also last question is do you have any idea how to change the stereo clock from 24hr to 12hr
thanks
Hi Sohail.
Good to know you got your stereo sorted and thanks for letting us know.
The 1.4VVTI engine is timing chain, not belt. You shouldn't have anything to worry about unless there's been a lack of maintenance. My 1.4 T2 is on 80.000 miles and is still very quiet.
The clock should be adjustable via the options menu. To access this press the mode / ent knob on the right hand side of the stereo. You then rotate the knob to the option you want (ie clock) and press the knob again to select. Then you rotate the knob again to the desired 12/24hr setting. Once set, just leave the stereo alone for a few seconds and it will automatically go back to the normal display.
If you want to keep an eye on mpg, press the Trip/Navi button until it shows the average MPG, pressing again and holding the button down until it beeps will reset it to zero. (this works for the average speed too).
Anything else, just let me know.
Cheers
  • 9 years later...
I bought this one and fitted it in and does work nicely 🙂
thanks
for anyone here years later that has lost the images, I have the same W58814 stereo (newer with smaller white plug for ext CD)
google something like
Car Audio MP3 USB Interface Aux Adapter For Toyota Corolla
you're looking for a pic like the attached, white plug that'll fit the stereo pic he's got above, wire to square box with yellow label (white label version had the wrong pinout in my experience) and a 3.5mm jack and a USB jack
