Avensis T25 Estate Abs Error
Duggerz
Hi All,
My T25 facelift estate has done well, but recently the ABS light has been coming on, but there's more to the story. About a year ago I had a Front NSF wheel bearing replaced by a mechanic because it needed a press and I don't have one. The mechanic heated up the hub to cherry red to get the bearing in. Hmmm. Anyone want to wager that the problem is the ABS sensor in the FNSF hub?
Anyway, I need to confirm the problem, could someone please guide me through the correct way to diagnose it?
Ian
