Rav4 P1250 Fault Code
Turbo123
Hi all, I am posting this as this forum helped me eventually solve this p1250 fault code and power loss when travelling uphill in high gears(4,5).
After being told turbo fault, and then maf sensor it turns out to be the pressure boost sensor which is located on the right hand side of the engine. The little nozzle was broken off and removal only showed this as it is connected to another nozzle that is located on the vsv by a small piece of rubber tubing.
So I have glued the piece together and after a run it all works fine.
Just have to buy another PBS just in case my DIY does not last.
2005 rav4 part no 89421-20210.
Hope this helps anyone.
