Help D4D Xtr
steve booth
I have found a a switch approx 1cm dia in the luggage area on the left hand side.
I have operated it but there is no obvious lights etc going on or off and the aux socket in the back still works.
I have been through the owners manual but can't find any reference to it.
Can anyone tell me what it does?
Thanks.
Do you have rear parking sensors?
It may be the switch to enable/disable the sensors.With the ignition on and reverse selected, try walking past the sensors with the switch in either position. If the sensors don't beep with the switch in one position and do beep with the switch in the second position, there you are.
