2009 Rav4 Windscreen Washer Jets
feeb
I've hardly any force in driver's side jet, passenger side ok. So first of all I swapped the jets over but this made no difference, still no force on driver's side. Took insulation off underside of bonnet and checked for leaks/blockage in tubes. Found nothing. The only thing I can think of is the connector where the tube splits and goes to driver's side. Could this be faulty??
Some of these Y connectors have a one way valve - could be that this has developed a fault. Presumably a new Y connector may be the remedy
  • 5 months later...
Hey, I have this exact same problem, where did you get your Y Connector from Feeb? I am having so much trouble finding one to replace mine!!
If you can't locate a new valve you can always poke the inside with a small screwdriver which will give full force to the jet but of course will allow the water to drain back to the washer filler bottle if not used on a regular basis.
Mike.
Part number 85381-28020 from your local Toyota dealer
Thanks both for your advice and thank you Devon aygo for the part number! I will order one from Toyota tomorrow and hope this will be the fix, will keep you posted! :)
