T27 60 Plate Estate Key Battery Low
thaiad24
Hi I keep getting a warning that the key Battery is low
its not a key per say, its one of those you leave in your pocket and press the start button
i cant see how i can change it as it looks as tho it simply doesnt open?
any ideas?
I'm pretty sure it tells you how to change the Battery in the owners manual. Or try removing the hidden key blade and see if there's a screw or something in there.
slide key 2/3rds of the way out then gently lift and it should pop open
Pull the key all the way out, put the end of the key into slot on the end and twist it will come apart.
