T25 Toyota Avensis Tailgate Handle Broken
avensisd4d786
went to open my boot today, the bl**dy handle has fallen off. (highlighted in red)
its held in by 5 nuts and studs and one clip.
the plastic has broken where the studs are affixed too.
Toyota want £55+
is there a temp fix? maybe some kind of glue.
post-125194-0-98388100-1414765495_thumb.
post-125194-0-51087000-1414765769_thumb.
  • 2 years later...
I would use two-part epoxy putty. It bonds well to relatively smooth surfaces and should do the trick. Tape the handle in place while it hardens.
Scrap/breakers yard.
Bought a new one myself, 60 quid but will keep the car right for another few years. Dont want mine rubbing on the boot and causing rust
  • 3 years later...
Can you write here the part number of the tailgate handle? I drive a 2007 Avensis hatchback.
Thanks a lot!
Thanks a lot!
7680105010 or 7680105060
  • 1 year later...
Toyota want £55+
i got a spoiler for my 2014 avensis and the guy who painted it to match the car it can with screws to drill the boot screw in but he advised me to be better put on with glass glue so he said and well tbh great job
Mine broke too, unfortunately I cannot find a spare part, any suggestions?
  • 8 months later...
Grey colour tailgate handle toyota avensis 2006 diesel hatchback
Toyota want £55+
you not try this stuff from ebay
https://www.ebay.co.uk/itm/273821192351
J-B Weld Original Cold Weld Steel Reinforced Metal Epoxy
  • 1 year later...
I think you have to be able to remove the handle to replace the number plate bulbs. Obviously not easy if it is glued in place.
Nah you dont ..did both bulbs yesterday
I did have to remove the boot trim and the surround that goes over the two number plate lights 5/6 10mms just unplug the boot switch wire you dont have to remove it
Mind the post is 10years old so he prob got one by now lol
  • 2 months later...
The bulbs for the plate lights are serviceable by prising open the rear boot inner compartments to access.. I noticed my tailgate handle was loose. The nuts can work loose on the inside. Just needs tightening. I can't imagine glue holding up the force needed to operate the tailgate.
