Passenger Door
susie69
Right last night lashing down with rain I'm in my seat (driver obs) hubby went to get in door still locked NOT HAPPY lol ssshhhhhh. So how do I get both doors to,unlock at the same time??? I've tried leaving my door open and holing in the key but nothing happened so to,save him getting even more with my little beauty HELP cause all I heard was F**king 20grand car and I can't even get in the f**king thing ahahahaha
Sent from my iPad using Toyota OC
Do you have a door locking switch by the power window and mirror controls? If so, was this switch depressed which locks the doors?
There are two ways you can set get your passenger door to unlock along with the drivers, at the moment your car is programmed not to unlock the passenger door when using the keyless entry your dealer can reprogramme the car to unlock both doors or you can press unlock twice on the key
Wait until it freezes. You'll have great fun closing (or not) the windows once open. A royal PITA, but relatively simple fix once you know the trick. Will try to find a link to it later.
press the unlock button twice, not too fast and not too slow either.
There is a way of setting keyless entry to open both doors. Check manual or ask on gt86 owners club forum. I did it on mine but it was ages ago.
I have asked, it seems I we'd to go to Toyota to reprogramme it. I will just use the key when hubby's comes out with me which isn't that often anyway but thanks
Sent from my iPhone using Toyota OC
You don't need to go to Toyota. I think it's shut the doors and hold open button on fob for 5 secs to set both doors to unlock. gt86 owners club forum will definitely know.
To set the passenger door to unlock at the same time as you unlocking the driver side door do the following:
Use the drivers door handle to open the door
Leave the door open and hold the lock and unlock buttons on the fob for 5 seconds
You'll hear a couple of beeps
Voila - your drives handle now opens both doors.
This can be repeated to reverse if wanted!
