Can Secondhand Injectors Be Programmed Into Ecu 2.0 D4D 04
Hi I have a corolla verso that will start then cut out when cold with vsc /trc /engine management light on .After this it will drive fine and lights will go off when warm after key as been removed .The car is in the garage having the injectors removed for test after an injector leak came on the computer. My question is can secondhand hand injectors be programmed into my ecu or do they need a code from new any help is much appreciated thanks
