Celica Tsport Exhaust
StuyTSport
Hi all,
Just brought a TSport and the rear exhaust box has a small hole, after being told the stock replacement is 400 I thought it's time to upgrade to stainless. Problem is people seem to make cat back systems for the 140 but 190 models seem much more problematic, any advise on what you guys have or did would be greatly appreciated.
Stu
Most go for custom as you can get a cat back system for under £400, whereas a backbox on it's own from the likes of Blitz, HKS, Greddy etc. will cost you closer to £600 and over.
Funky power do some exhaust for the celica, you just have to search as they are out there, or you can go on the likes of nengun and import direct from Japan but it's not always cheap.
Just remember if you do find a exhaust all are just axleback exhausts, even though some state cat back they are not they still only connect to the flange by the rear axle hence axleback.
Small hole? Might be fine to use some copper sealant on a small piece of aluminium wrapped around it, with some jubilee clips? Done this before, lasted years.
