Avensis 2.2 Diesel Tr180 Engine Number
Dave lewis993
Could anyone help me I have recently bought a 2007 Avensis and want to check that the engine number is the same as on the log book as I know there is a history with the engine being replaced due to a fault on some of these, the trouble is I cannot find where it is stamped on the engine, does anyone know where it is?
Cheers Dave
The engine number is stamped into the cylinder block:
In the block casting ABOVE the starter motor in the case of an original engine.
In the block casting INFRONT of the starter motor in case of a remanufactured engine.
post-45863-0-87138900-1415994410_thumb.p
Thanks for your reply mate I will have a look tomorrow in the light
Thanks spot on where you said it was at the r/h side of the starter moter by the gearbox
It will be spot on as he works for the man! And knows his onions! As well a few things about Toyota's an all :)
