03 Rav4 D4D Turbo Whistle
JZA80
I have a bit of an issue that I'd appreciate some help with.
I have an '03 Rav4 D4D (80K miles) that has developed a whistle when accelerating, I can still feel the turbo coming online but there is a drop in power and it is bogging down under wide open throttle. It's definitely turbo related but can't find any obvious leaks after a visual inspection of the pipe work and there are no warning lights coming on.
Before I start stripping the IC and pipework off to inspect the turbo, I was wondering if anyone had any ideas what the problem could be? I've read that it may be caused by a sticking EGR valve but that this normally brings up the engine warning light, which I'm not getting.
does the noise stop when let go of the accelerator...if yes, Sounds like what I am getting. any chance of a video?
The whistle can be heard whilst accelerating as the turbo spools up, off boost the sound goes. I know there's a boost leak somewhere, I suspect it's either the egr valve or there is some damage to the turbo, just thought I'd ask for opinions before stripping it to inspect the turbo.
