Is It Possible To Replace
Leonel
Is it possible to replace a toyota Vitz 2005 push button start to a normal key ignition type ?
ECU for Smart Keys are very expensive I don't have money to buy one
Not easily as you would have to purchase a complete steering shaft and motor assy along with an ignition barrel, steering column shrouds, dash wiring harness, ignition switch Etc this would cost way more than the ECU
So where can I replace the ECU that as keys with a used one from a Vitz 2005 same model ?
