Vsc Trc Off And Engine Light On
pancaz
Hello
I have 2005 TOYOTA AVENSIS T3-X 5 DOOR HATCHBACK. I have this car since 2008 and never had any problem and I make sure that it's serviced on regular basis. This morning, I noticed that VSC, TRC Off and Engine light has come on. First only VSC and TRC Off lights were on but when I restarted the car Engine light came on too. Any idea what it could be.
Any help/advise would be highly appreciated.
Many thanks & best regards
To correctly diagnose your problem you need to buy a compatible code reader (OBD2 compliant). These are available online for under £10. The fault could be a variety of things from oxygen sensor to vvti OCV. The reader will point you in the right direction.
