How To Check If Rav4 Has Dpf
garichd
How do I check if my RAV4 is fitted with DPF.
Its early 2010 model - 2.2 D-4D XTR.
Hi, mine is a late 59 plate, just coming up to 5 years old.
Mine does not have a dpf and does not have the face lift grill.
When I asked the question, I was told to look over the back of the engine and look for pipes and wires going from the bulky exhaust into the bulkhead. Mine does not have any.
Mine also has a sticker in the back window Toyota Optimal Drive.
Mine was first reg end of Sept 2010 and I queried the same question with Toyota, they said it had a DPF and the system was similar to that on the D-CAT version although mine is a manual gearbox.
Peter
