Idle Rpm Auris 2.0 D-4D Tr?
jazzyman
Any idea what the correct idle (tickover) RPM should be on a Auris 2.0 D-4D TR? My Auris is running at 1000rpm which seems to be a bit on the high side?
1000rpm if you're using the heater/climate control and if you're engine isn't fully warmed up.. and ambient temp is between 0 and 10 degrees.
1200rpm if all of above but ambient temp below 0 degrees.
If ambient temp over 10 degrees then normal idle speed.
Thanks, that does make sense. I have only noticed the higher tickover during this recent cold spell.
Just wondering what the normal idle speed should be with ambient over 10 degrees?
if it's like a 2.2 then 800 when warmed up & no additional demand (ac etc.)
