What Oil Do You Recommend In An Rav4 T180?
Jonny jb
5W-30 for a diesel engine without a dpf. Should meet API SL, SM or SN specs (SN being the latest).
if it's a T180 it has a DPF (DPNR) so it needs to be low ash (C2).
Which do you recommend hioping to carry out the service soon. Thanks
For your DPNR equipped T180 Toyota states:
Preferred grade as 5.9lt of 0W30 ACEA C2, Toyota part #
5lt - 08880-82871
1lt - 08880-82870
Allowed grade as 5.9lt of 5W30 ACEA C2, Toyota part #
5lt - 08880-83389
1lt - 08880-83388
So long as you use one of the grades above you will be fine the ACEA C2 bit is the most important part as the denotes to oil has a "low ash" make up making it compatible with your diesel particulate filter, oils without this ACEA C2 specification are more likely to cause a premature blockage or failure of your DPNR.
