Fuse Location, Toyota Avensis, 1.8 Petrol. 2002 Model.
cckw
The passenger window will not work, driver side is fine, check fuses first, so I find the fuse locations via the manual with the car, but there appears to be no fuse for the power windows, is this correct or have I missed something?
Any help would be appreciated.
Just double check you haven't pressed the window lock switch on the drivers door, this disables the operation of all the other windows
Many thanks Devon, on arrival at work this morning, I wondered what that switch was for, just forward of the window switch controls, yes, you are 100% correct, it was turned off, classic mistake on not reading the drivers manual.
