Water In The Passenger Footwell
fisherman44
Hi, can any body shed any light on a problem I have. I own a 2008 Rav4 Mk3 and just recently we had some very heavy rain and I found quite a big puddle of water in the footwell (passenger side). Any ideas please. Thanks Mick.
Check the pollen filter to see whether it is blocked.
Moved to Rav 4 club
Have a look at:
Im not sure how water on the passenger side floor relates to a blocked pollen filter!
What you describe is a fairly common problem though not often seen on cars after late 2007. It's usually due to a failed windscreen cowl seal and there is a bulletin on installing an improved seal. Cowl _leak REVISED-2.pdf Sometimes the problem starts after having a replacement windscreen fitted when the seal is damaged and is often worse when the car is parked on an incline. If the pollen filter is damp - the problem is almost certainly the cowl seal.
