Witter Ty123 Towbar Replacement Swan Neck Towbar
rayh09
Hi all,
I have a 3 door Rav 4 diesel with a Witter TY123 towbar fitted. I need a replacement detachable swan neck towball. Can anyone help or point me in the right direction?
Many thanks !!
Ray
post-145091-0-06273400-1417528030_thumb.
Access the following website http://www.witter-towbars.co.uk/towbars/findTowbar1.php
Scroll down to 'locate a Witter fitter' and enter your postcode. You should then be able to contact your local fitter re getting a replacement swan neck.
If you put in your Reg number in the yellow number plate on the left, it will come up with what tow bar suits your model car and price.
The OP already has a Witter tow bar fitted and knows the model no - needs a replacement detachable swan neck.
Sadly I can't buy the swan neck towball separately - so anyone have one they don't want ???
Give this shop a call, i used to work there, they will be able to tell you 100% if you can buy the parts you want, that are based in Upminster, Essex. 01708 223334 Towrite.
Mike.
