Emissions Diagnosis P0420
Hi - this is a bit of a cry for help!
I have a 2000, 1.8 Celica (140 bhp).
Had P0420 and P0171 fault codes. I cleaned the MAF and replaced spark plugs and pre-cat sensor which didn't help so, I took it for a diagnostics at the local garage.
They basically said the cat had died and needed to be replaced because it had high C02 emissions indicating that. So on their advice, I had the cat replaced.
This cleared the P0171 code, but P0420 is still there. It's a Catalyst System efficiency running lean on Bank 1 error.
At this stage, my last thought is I should run a smoke test to check for leaks in the header or manifold. I've spent £350 and haven't yet fixed this so any help or advice would be massively appreciated!
All the best
  • 1 year later...
All the best
Did you manage to fix this? What was the problem?
Was there any leaks? I am having the same issue with p0420 but passes mot no problem.
