How Long The Coolant Fan Start Working.
nico1135
Hi sir ...ever since I bought this car I have never seen the coolant fan of the engine working. ..While the engine is been started for 30 minutes ...in this whether. ..but it doesn't show the car is overheated. ..only the blue light sometime appear on the dashboard and goes off... (temperature light ).
Your car should have air-con, so switch it on and observe to see if the fan is working. So long as the air-con works!
By process of elimination you should determine if the fan, relay, or thermostat switch are faulty. Also check connections.
Be careful working around the fan in case it starts operating unexpectedly!
