Vsc, Trc Off & Engine Malfunction Lamps Glowing Together
sanjay123
while driving about 10 days ago, suddenly i realised that i have lost power to the car and the car is not moving while pressing the accelerator. I shifted the gears in vain for some time. After a minute i was able to drive and the car drove normally. Later I found that VSC, TRC OFF & Engine malfunction lamps glowing together on the dash board. But after sometime these lamps turned off automatically by switching off the car's ignition.
I checked the MIL and found ECU#10 with decription " Fuel system leak detected-Large leak".
I had filled the tank full one day before when the lamps appeared and the tank was almost full when the lamp glew. I tightened the cap of the tank again and resetted the MIL.
after approx one week, I got the same problem with identical symptoms & the same lamps glowing and identical MIL. The lamps got reset in the same way as earlier.
is there anybody who can advice me what i should do to troubleshoot or i should visit the service center?
Topic moved to the Avensis club.
