2003 Avensis (Vermont) Rear Screen Demister Fuse
ajm5807
Apologies for this question but I'm not too hot with DIY on cars
I've found the fuse-box inside the saloon but when I've removed the storage box covering it, it is missing the fuse identification sticker.
The problem I have is that the rear screen demister doesn't seem to work at all, although the LED on the dashboard switch lights up when selected. I've checked the 30A and 25A but they all seem ok (mini fuses by the look of them)
Could anyone help me identifying the fuse or any other ideas...bearing in mind my lack of skills lol
Andrew
On the 2008 petrol the 'rear window defogger' is fuse 69 - engine ccompartment - type b - 30A - RR DEF.
Your car is could be the mk1 T22 or mk2 T25.
I googled the following which shows T22:
https://www.google.co.uk/search?q=toyota+avensis+vermont+2003&espv=2&tbm=isch&tbo=u&source=univ&sa=X&ei=ZqaOVMCvGeGV7Aam14GgCw&ved=0CEAQsAQ&biw=1600&bih=785
If your car is the earlier mk1, then I have the fuse positions from my even more earlier 7A-FE. There should not be too much difference.
Avensis T22 fuses 228.pdfAvensis T22 fuses 229.pdf
Otherwise you need somebody with a T25 to assist.
Konrad
