Alarm/central Locking Problem
snoged
looking for a little advice with this
key would not open the central locking this morning so i unlocked the drivers door the the key started up and all was fine untill i parked and the key remote would not lock so had to use the key in the drivers door one thing i noticed is when i shut the drivers door the interior lights went straight out i thought these dimmed slowly or is that just me ?
anyway replaced with a new Battery (tested good) and still no response from the alarm/central locking
any help with this is much appreicated
I'm pretty sure the interior lights dim slowly if the ignition is switched off, but go straight out if the ignition is on. Maybe your car has a problem that it thinks the ignition is switched on and therefore it won't allow you to use the remote locking.
