Airbag Warning Light Detached From Dashboard
Got a new Aygo Expression last month. Perfect in every way, except the airbag warning light (sited above touchscreen on dashboard) has become detached from dashboard. The unit is now sitting loose behind the gap in the dash. I can reach it, but can't find way to reattach from the front. Is is possible to remove a part of the dash in order to fit this back in place? If it's possible to remove the touchscreen unit I might be able to reach in from underneath. If not an easy fix I can ask dealer to repair as might be covered by warranty. Any suggestions would be much appreciated.
Take it back to Mr T
Take it back to the dealer for them to sort.
how did it become detached ???
  • 9 years later...
Did you get any replies to this of how to fix back in position as just happened to my daughters 2014 Aygo?
Presumably the OP took the car back to the dealer, as advised, because it would have been under warranty, and got it fixed that way. Aside from that, she only posted once, and hasn't visited the Club since December 2014.
