No Compression In No: 3 Cylinder
keygenie
hi i`m new to here so bear with me thanks.
i got a celica 1.8cc vvti on V-reg.
mileage is around 145,000 ish
it runs only on three cylinders does not burn oil or loose water.
had a compression test done came up with cylinder no: 3 no compression at all
same result with dry and wet test also a diagnostic test came up with pending fault no: 3 cylinder.
i did the paper test on exhaust and flaps like hell so is it valve problem?
runs ok`ish just not got as much power it should have also water temp stay`s normal
one more thing i seen the engine management light stay on and some times to start flashing then back to constent on again any genuine advise esp from full turm mechanic can be of great help please.
shame lovery car want get it running as it should again i perched it like this so not much history on it sorry
post-145450-0-18703600-1419052528_thumb.
Hi Drew
It sounds very much like you have a valve burnt out in the head and the only real answer is to take the cyl. head off and have a look. Could be a bit of messing about and a tad expensive but it seems the obvious answer.
Mike.
thank you mike for kind advise looks like be a garage job then m8
all best for xmas mike
Seems like the only real way to find out is whipping the head off. Good luck.
thanks guys yes got take it in to have head took off then take it from there
