Changing The Key Fob Battery
redlew
Morning all
The Battery needs changing in my mark 2 key fob.
I unscrew the small screw at the back and open up the Shell leaving me with the black internal square.
There are two tiny screws that need to be unscrewed . One comes out but the other is stuck and the head is chewed up.
Any suggestions as to how to get it out, please? I'm a bit stuck if I can't get it out but don't want to damage the flimsy internals.
Anyone know the replacement screw size, please and where I can get one?
Morning all
The battery needs changing in my mark 2 key fob.
I unscrew the small screw at the back and open up the shell leaving me with the black internal square.
An option would be to drill out the head of the screw, replace Battery and fit the one good screw back in,and see if it stays together when you fit it back in the case.
Think it's a tight fit so little chance of the Battery not making contact in the case,if not add a little packing to the case. Other option new one :(
I have a feeling that new one will be Mr T which is going to cost. The drill will have to be tiny -not much bigger that a pin -might try a jewellers to see if they can get it out.
