Front Parking Sensor Issue
TheSpud01
Wondering if anyone can help. Have the T180 model and has front & back parking sensors as standard.
I believe there is a switch/light next to the cig lighter under radio to turn the front ones on/off. This is supposed to have a flashing green light. This does not have any power going to it.
Could someone help locate where the relevant fuses for this would be or wiring to try diagnose.
The back ones seem to work ok.
Fitting instructions & user guides available here: http://www.toyota-tech.eu/Aim/Aim.aspx?pubtype=AIM&menuitem=3
Select: RAV4, 2005/11 FMC Gen 3, then choose which option you want & finally select Parking Aid system. This will give you several options assuming you have Toyota sensors fitted.
Thanks. Mentions checking fuse. Any idea which fuse number it is?
If your on/off switch for the front sensors is a small round button with an led in the middle then you have a TPA800 sensor set fitted each harness front/rear is separate if you read the fitting instructions they show where each harness is joined into the cars loom the fuse for the front / rear is in line on the power feeds for each front/rear harness.
