Rav 4.3 Exhaust Blow
stevedale5
Hi
Just noticed a slight blowing noise from the exhaust front pipe/ DPF to turbo took heat shield off black sooty Mark from flange that bolts onto turbo all 3 nuts tight on flange seems to be blowing between flange and pipe could it be gasket or is flange welded on inside as there only 3 spot welds on outside anybody had this happen before its on 2008 D4D 2.2.
Regards Stevedale5
Sent from my iPad using Toyota OC
