Castrol Oil For Toyota Avensis D4D 1Cd-Ftv
avensisd4d786
all below are 5w 30 fully synthetic;
Castrol Magnatec 5W-30 A1: benefits and specification
As part of the Castrol Magnatec range, our 5W-30 oil contains intelligent molecules that cling to your engine and form an extra layer that protects from start up.
Another advantage is that Castrol Magnatec 5W-30 A1 uses less fuel compared to other oils, allowing you to drive up to 370 miles a year further*.
  • Uses fully synthetic technology.
  • Provides protection during the critical warm-up period and beyond.
  • Bonds to metal surfaces making engine parts more resistant to wear.
  • Provides superior performance under extreme cold start up conditions.
Is Castrol Magnatec 5W-30 A1 suitable for my car?
Approvals & Specifications:
  • API SM/CF
  • ILSAC GF-4
  • ACEA A1/B1 or A5/B5
  • Meets Fords WSS-M2C-913-C, WSS-M2C-913-B,WSS-M2C-913-A
*data based on 5W grades vs a 15W-40 in Industry approved test NOTE: 5W-30 oil is only suitable for cars that can use an ACEA A1/B1 fuel efficient product. Please consult the vehicle handbook to confirm the oils suitability.
Castrol Magnatec 5W-30 C2: benefits and specification
Choose Castrol Magnatec 5W-30 C2 and its intelligent molecules will protect your car’s engine during the critical warm up stage when up to 75% of engine wear occurs.
  • Combine with synthetic technology to provide increased protection in high and low temperature applications.
  • Provides continuous protection for all driving conditions, styles and temperatures.
Is Castrol Magnatec 5W-30 C2 suitable for my car?
  • ACEA C2
  • PSA Approval B71 2290
  • Meets Fiat 9.55535-S1
________________________________________________________________________________________________________________________________________________
Castrol Magnatec 5W-30 C3: benefits and specification
Choose Castrol Magnatec 5W-30 C3 and its intelligent molecules will protect your car’s engine during the critical warm up stage when up to 75% of engine wear occurs.
Is Castrol Magnatec 5W-30 C3 suitable for my car?
  • ACEA C3
  • API SN/CF
  • BMW Longlife 04
  • Dexos 2*
  • MB-Approval 229.31
  • VW 502 00/ 505 00
*Specifically developed for engines requiring the GM dexos2 engine oil specification
according to Castrol oil checker I should be using A1, what is the difference between a1 c2 and c3.
I need educating on the oil side of things so if someone can spare me a bit of knowledge this would be appreciated.
I have just bought c3..can I use or will I have to take it back.
ACEA A1(petrol)/B1(diesel) spec provides good fuel economy when used in either a petrol engine or a diesel engine without a diesel particulate filter.
ACEA C1, C2 & C3 are for diesel engines with a diesel particulate filter and either a 'low ash' or 'mid ash' requirement (known as SAPS - Sulphated Ash, Phosphurous, Sulphur). Not using a low ash oil can result in the dpf becoming blocked. The difference between these 3 grades is the amount of ash they produce, and in the case of C2, its suitability for optimum fuel economy/performance.
Not sure whether C3 is suitable for yours.
Thank you Mike that helps, Hopefully Devon Aygo/Mistermena will see this soon
A useful brief explanation of the ACEA grades here: http://www.opieoils.co.uk/c-789-acea.aspx
You can use the C3 oil in your car it will cause no harm but an A1 grade oil is most likely cheaper and perfectly fine for your car.
Castrol magnatec 5w30 A1 fully synthetic is what Id go for.
But since mine has been to the moon and back in mileage I could use 10w40.
What about c2 mate? and thanks for answering I know you know your onions.
C2 would be fine but is overkill as any C# oil would be, as your Avensis does not have a DPF/DPNR.
Thanks this Castrol is a very good buy 2 litres for £4.50 so I got 6 litres for £13.50, my takes 5.9 and does loose any oil between services.
Thank you Lee, I will stock up on the stuff now
