Kenwood Headunit
Bibbs
DPX-6100MD
Comes with adaptor harness, AUX cable and KCA-RC700A remote for the steering wheel.
It's silver and the front slides down to reveal the CD slot ..
Reason I'm selling, just upgraded to a similar style Alpine. Make me an offer ..
BTW there is no damage to the unit .. it's my dash that's broken :)
And the spec ..
Kenwood DPX-6100MD (ke-dpx6100md)
Dual size MD/CD receiver
It corresponds to the CD-R / the CD-RW. (We do not correspond to the MP3.)
47w x 4 high power amplifier built-in.
6 hole DSP / 7 band EQ built-in.
2 mode 13 band spectrum analyzers.
NEW sliding panel mechanism (manual).
Security cord/code correspondence for robbery prevention.
1.5v high voltage RCA1 pre- out.
Remote control correspondence (KCA-R7 and RC600 selling separately).
CD text indication correspondence (at the time of CD changer connection).
Separate power IC.
[ MD section ]
Frequency characteristic: 20Hz - 20kHz (+ 1dB)
S / N ratio: 90dB (1kHz)
Dynamic range: 90dB
Stereo separation: 85dB
[ CD section ]
Frequency characteristic: 10Hz - 20kHz (+ 1dB)
S / N ratio: 93dB (1kHz)
Dynamic range: 93dB
[ FM section ]
Reception frequency range: 76.0MHz - 90.0MHz (100kHz step)
Practical speed: 9.3dBf (0.8 mu V / 75 Omega)
Frequency characteristic: 30Hz - 15kHz (+ 3.0dB)
Stereo separation: 40dB (1kHz)
[ AM section ]
Reception frequency range: 522kHz - 1629kHz (9kHz step)
Sensitivity: 28dB mu
[ EQ ]
Equalizer - center frequency (Hz): 60, 160 and 400, 1k, 2k, 6k and 16k
Variable range: + 12dB
[ Audio section ]
Installed capacity: 47w x 4
Rated output: 29w x 4 (4 Omega, 1kHz and 10% THD)
Pre- out level: 1500mV (FM/10k Omega)
[ Common section ]
Power source voltage: 14.4v (11 - 16v)
Largest consumed electric current: 10A
Pad size: 178w x 100H x 155dmm
Mass: 2.9kg
Was hoping for closer to £250 .. I'm not desperate .. It's just sat here ..
MMMmmm Soooo Tempted.... <_<
But I really need to get my exhaust sorted first :(
I am seroiusly intrested. I'm after a 2DIN headunit and that one looks perfect.
Seroiusly though, I really want that one. What are you prepared to come down to?
The main issue is my new one cost £300 so I'm trying to get as much back as possible ..
The remote was about £35 and the AUX cable (for my Xbox plans) was about £30 ..
At a push I may come down close to £200 ..
sorry mate. I just got some bad news for you.
I cant buy it. basically, I can't afford it. My rear shocks are leaking and I see it as an excuse to upgrage so my money has to elsewhere for now
I was really intrested in buying it. you do not know how badly I want a 2DIN head unit for my car and that would look perfect
I will let you know when i can buy it, but if you sell it before then, no biggie. just let me know if you have others like it
Thanks anyway
Sorry to hear about your car ..
I can get them direct from Japan .. as I did with a few Alpines, the main cost is shipping. I suspect that one will still be on my desk in a few months ..
nice one.
don't hold on to it for me though. If you can find a buyer for it. go for it.
If you do sell it though, let me know what styles you can get and how much for in total. My parts guys were trying to sell me a sony unit which comes standard in a new celica. £375 normally, they would let me have it for £250 cash. how much can you get it for?
Sony .. erm, can I wear gloves so I don't have to touch it ??
What's the model code ?
sony? that bad are they? my 6x9's work brill
don't worry about the celica one. I thought about and I want that kenwood one instead
Aparently Sony are a few years behind in the technology and a quite prone to breaking ..
They are expensive cause the Ripspeed kiddies buy 'em ..
That makes sense. I bought them as i know absolutly nothin about sound systems.
I'm just going from my mate "in the know" ..
