6Th Gen 2000 Gt Head Gasket Symptons
JoeHarrop
1995 2000 GT twin cam 16 valve blows water out of radiator cap when removed.
There is no oil in the water, and no water in the oil, also heater is cold. Do you think this is a head gasket ?
I do remember going over the RPM in third gear because it cut out momentarily. Does this help.
JOE
Sounds like head or head gasket troubles to me. Youre getting combustion gases passing into the water chambers.
Thanks Alan. Thinking about your remarks they makes sense. That is where the pressure is coming from.
Cheers JOE
