Rear Window Washer
kenny1954
when I press for rear washer no water is coming out and the washer bottle is full and front work fine, any ideas what could be wrong, i.e is their a fuse or something else
Is the rear washer jet blocked?
Have you checked whether water is getting through?
im not sure but their is no sound when I press for washer, I,e pump noise
Hi Ken,
First thing is, can you hear the pump motor working when you try the rear wash? If not then the washer motor has died.
Here is a recent link:
http://www.toyotaownersclub.com/forums/topic/165079-infoadvice-needed-replace-98-avensis-washer-pump/
Konrad
You just posted as I was composing my previous reply.
You need to change one of the motors in the washer bottle, located in the front right wheel arch bumper.
It is not too difficult to change, just access by undoing the undertray and wheel arch liner.
Konrad
Using the photos from the link, local spares shop or even Halfords. Try a breakers to see if they have what you need.
