6Th Gen Celica Maintenance And Mpg Log Spreadsheet
PT1
I've driven 6th Gen ST202 Celica GTs for many years now, and have created, with the free LibreOffice program, a maintenance spreadsheet:
https://www.amazon.co.uk/clouddrive/share/bA7vfsLP9DUnzLOpmnxpdOekZ9eKfz1mdglFe8at0FE
I'm doing a lot of my own maintenance now. This spreadsheet includes some notes from Google searches.
I welcome any comments for change/addition?
(It's easy to overlook things like the power steering, the fluid in mine is black, might not have ever been changed? It's interesting that it needs ATF fluid).
Paul
Oops! I tried the power steering fluid change. It appears the return hose is the one underneath the power steering reservoir?
This was the way I changed it in the end... Repeatedly ran the engine for 3 seconds, emptying and refilling the reservoir before each run.
It may not be a perfect way, but it appeared to remove the black fluid each time (might never have been changed?).
Updated xls: https://www.amazon.co.uk/clouddrive/share/VM2MNaC2ZH12W7tqcMjS3gNBhQGXFXUiDAVEdrS6ZeM
Paul
