Handbrake Light
bluerav4
Hi
Hope someone can help me with this I've noticed today that when the handbrake is applied the red light is not coming on.
I applied the handbrake several time and it came on then went off again.
Is there anything that I maybe able to do myself to try and fix this? Or does it mean an expensive fix
Thanks guys
The car is a Rav 4 T180
Hi Sheen, think the first thing I would check would be the switch which will be by the handbrake lever under the centre console.
go to the top of the RAV4 page and you will see one listed as technical information by Anchorman
Scroll down to the 4.2 section and handbrake adjustment and you will find one of the excellent articles by that missed member which gives clear instruction on how to remove the console.
Keep us all posted how you get on
Del
Hi Del
Thank you very much for your reply
I have found the topic you mentioned will hopefully try and get it sorted tomorrow now.
The light shows up when you put the ignition on so its not the light itself and more than likely as you said it'll be the switch
Will update when fixed
Thank you again
