I just bought a 97 toyota corrola CE. I found no "Toyota" sign or logo anything on the engine. Is this a real toyota engine. Or maybe I didn't find right spot for it. Any help? Appreciate!!
Take a pic of the engine...
Any sort of engine code printed on the engine?
Relax man.... It's a 4A-FE. Mine doesn't have markings either. And mine's a US 97 CE also.
If you need specs on the engine, it's a 4 cylinder, electronic fuel injected, 1.6 economy engine. 95lbs of torque, and 100 horsies. If you're new to the forums, you can also check out www.vvti.net which is US based. I hope this helps.
:arrgg-matey:
