1996 Celica Horn Problem
stiz
When I switch off the engine and withdraw the key I have an engine management light, oil warning light and the blower is running. With the horn fuse removed the problem is cured. Would an earth fault in the horn wiring cause this problem? What else does the horn fuse serve?
