Electric Window Relay (Carina E 2.0 Gli)
Hello
Can anyone tell me where the electric window relay is?
I am at work and don't have access to the manual and i suspect i tried to open a window while frozen a blew a the relay/fuse.
I have checked the standard fuses and some of the larger relays and they look fine. I have lost three of the four windows, only the drivers side is working.
any help would be much appreciated
thanks
Sounds like you've pressed the window lock button ?
Sent from my iPhone using Toyota OC
Yep! realised about an hour after i posted this.
I my defence i had just had a wisdom (ironic) tooth out and i was dosed up and feeling groggy so not thinking straight.
Thanks for the help
