Engine Oil For Sr180
Swoop42
Hi all! I just wanted to know what grade, ACEA spec and brand of engine oil other SR180 drivers are using?
Wherever I look I seem to get contradictory information so figured it would be worth asking those that actually own the car!
Thanks in advance
Sent from my iPhone using Toyota OC
I use petronas syntium can't remember much else been to sleep since then but it meets all Toyota requirements and I have used most of the top brands and petronas seems the best in my opinion
It has to be C2 rated for your D-CAT. That's probably the most important one.
Your manual should tell you specs. though.
Thanks for the replies so far.
I thought C2 but when I phoned my local Toyota they asked what the handbook said (ACEA B1) and said go with that.
When a mentioned about C2 being for engines with a dpf there was a pause before again being told to go with what the handbook said...
Ye go with the c2 or higher and choose your brand your comfortable with and happy to pay the price of
