Which Castrol Engine Oil To Use For 2Ad-Ftv
ciuoks
Hi, I am confused with engine oil, in owners manual says to use ACEA B1 or C2, API CF-4 or CF, but when I open Castrol page ant enter the reg number they showing different engin oil. Please can somebody explain to me which Castrol engine oil I should use? car is toyota avensis 57 reg 2.2d4d 110kw
How much do you want to spend? If a standard UK spec. your car doesn't have a DPF so does not require C2 although afaik you can run it.
Either Edge 0W30 A5/B5 or Magnatec 5W30 A1 (also B1 & A5/B5 rated) would be my choice from Castrol (indeed they used to be when I had a 57 plate 2.2).
