Hi folks,
The passenger door (front) is permanently locked and I cannot open it.
The external and internal door handles do not work although they operate.
I have taken off the internal panel to the extent I can but although the wire connecting to the internal door handle works backwards and forwards it does not have an impact on the lock mechanism.
The inside lock (pull up to open push down to lock bottom left of window) operates too but does not have any effect.
Noticed a brass coloured peice of metal with two prongs (kinda) caught up under outside door handle and removed it.
Any ideas please.
