Horn Stopped Working, Any Idea?
Gomoca
Hi, first thing to check would be the actual fuse for the horn. Second thing to do is press the horn, if you hear a click sound when depressing then it means that the relay is working. If you dont hear a click sound then the horn relay may be gone. Other than that then it will be the horn its self.
Thanks for the reply, I have to figure out where is the fuse box ...
Yes! It was a fuse problem, already solved...
Thanks again,
Gonçalo
