Toyota Auris 2010 Electric Wiring Diagram
nestorasg
Hello friends.
I have a Toyota Auris 2010 model and I want to install a GPS tracker to my car and for the charger i want a voltage supply.
I want to know if is there any place under the steering wheel or under the passenger that are wires that take always from the Battery power to connect the charger.
Thank you in advance
Hello Nestoras - welcome to Toyota Owners Club.
Wiring diagrams should be obtainable from. http://www.toyota-tech.eu/
Be aware that whilst some information is free to access, some is chargeable.
Hello Frostyballs. Thank you for your answer.
Do you know if it's the same for Japan made models?
It may not be - the site is a Toyota Europe website, so will probably refer to the European built Auris (3 door was built in Turkey and the 5 door in the UK).
Hello friends.
I want to know if is there any place under the steering wheel or under the passenger that are wires that take always from the battery power to connect the charger.
Install it backside of radio unit, you have there plenty room and all the wires you need, permanent + , IG+ , "-" , etc.
