After Changing Fuel Filter On My D4D Fuel Leaks!
Reggie83
Hello,
After changing fuel filter on my 4d4 fuel leeks!! I think i tighten it all very good with new o ring and it looks like it is leaking from bottom plastic part ... did any one had this problem before?
I changed it also yesterday. Not sure, but look's fine. To be 100% sure i must check it over some day when i have more time. I tightened filter with hand, and level warning switch a little bit harder....
Hello,
what make filter did you use?
