Auris 2013+ Antenna Base Size
RyanBorg
hi i would like to upgrade antenna to a lower profile shark fin style one but i found a few sizes. Can somone measure the current base of the original antenna base so i can find a over all fin style replacement please thanks guys.
Ps: has to be ne latest auris model please thanks
I suggest you to order shark fin antenna from VisualGarage. Will certainly fit and looks nice, also colour-coded.
Thanks for your reply.. but i woudl still apreciate if anyone get me these sizess please as mine is still being manufactured and i cant measure it please so i have the correct dimensions.. length, width & height maybe please
I would suggest asking someone who has a late 2014 Auris - in case the antenna base was changed when Toyota revised the specs in the summer of last year.
  • 5 years later...
The shark fin will fit so long as do not have DAB
So I'll lose the DAB if I change fin?
Is that because the fin does not have connection or the reception get bad?
The cable connector seems to have 2nd port empty.
Pre 2015 Facelift both Radio & DAB go through the roof Antenna post 2015 Radio goes through the roof Fin and DAB is integrated into the windscreen glass, so fitting a Genuine Shark fin on a pre 2015 would loose the DAB.
Two connectors are power for antenna amplifier in base and antenna feed.
That leads me to ask, what are these sensors? One is rain sensor whats the other?
The long one is for the rain sensing wipers.
Later facelift cars have the TSS sensors where the hatched area is.
So the short one, i.e one attached to the rear  view mirror is for TSS, if that is equipped?
TSS is the box behind the rear view mirror. Wasn't an option before the 2015 facelift to my knowledge. Apologies for the outside pic, getting reflections off the garage roof.
@Devon Aygo Guessing the three lines are the DAB aerial on the 2015 onwards?
Thanks MagicBoy, I dont have that box on mine but I think I sussed out the sensor behind my mirror (the short one on my pic).
I think its for the Auto High Beam, to turn off high beam when it detects on coming vehicle.
Yeah, that'd make sense. Couldn't remember if the pre-facelift without the LEDs had it.
