2003 Avensis Timing Chain Snapped
greenboy
hi i have a 2003 avensis 1.8 petrol which is believed to have broken the timing chain so the aa say
i just wanted to know if this engine is interference or not many thanks
Yes the engine is interference, if the chain has snapped valves have most likely meet pistons.
Was there warning like a rattling chain. How much oil was in the engine and how often was it changed. How many miles has the engine done?
I ask these questions because some owners think the engine is better having a chain over a belt. My car has a belt which has been changed every 5 years ( never reach the 60000 miles). Yes it costs £140 the last time including replacement tensioner, but even if snapped my particular engine is non-interference.
The oil is very important to the overall condition of engine. Regular oil changes are a must, but some owners just don't care. I change my oil every 6 months on a 1998 car, owned since 2003.
Service history or some record is a must.
It will be cheaper to get a secondhand engine unless you know a good garage that can repair the valve & pistons. With the vvti known oil burning issue, it will be a lottery on the engine unless you can source a 2006 onwards engine.
Good luck
