Buying Guide For A Muppet!
The Bun
Hi guys, hope you are well.
I'm a newbie so please go easy on me .
I'm looking for advice on buying around an 05 Avensis , probably a petrol .
I used to deliver these , and really rated them.
I'm drawn towards the petrol as I really hate changing timing belts , & my wife will only be doing around 5k a year in it.
I'm fairly decent with the tools so my only real worry is this oil burning issue.
So here goes ,
Is there an actual definitive answer to when Toyota resolved this ?
I read Around 2005 , but is there an engine/vin I can check against ?
And,,, do the 2.0l suffer as well ?
Most posts I have read seem to be related to the 1.8 .
Thank you for any advice , cheers Bun
"the fix was made from July 2005 on chassis ending higher than E129522 "(thanks to devon aygo)
I hope this helps.
I had a 55 plate which had a sort-of tappet noise when cold. I reckoned it was the start of the oil burning problem. Couldn't tell you what it's engine number was tho.
Edit... I believe the 2.0 was unaffected, it's just the 1.8
